kostasv 0
Hello guys,
I own a Home Center Lite running v3.593 and recently I added two Vitrum Wireless on/off switches, each one with two channels, controlling different lights in the room.
I have added them with no issues to my HC Lite - all good so far.
When using the web panel or the iPhone app, I can switch them on and off, no problem at all (fantastic)!
My issues come when there is 'manual' interaction with the light switch and I physically touch the Vitrum switch to switch on/off the lights
When I touch to switch on/off the lights of the master, the lights turn on/off and everything works perfectly. The change is visible in both the app and the web interface.
When I physically touch to switch on/off the lights of the slave, the lights turn on/off but the controller is not showing the change, it is like lost in the air! Both the web and the app don't change status to show on/off, it is like nothing has happened?!? Is this normal? Am I doing something wrong?
I have no parameters, nothing changed from the original config when the devices were added, not even scenes yet on these devices, it is a simple setup and I can't figure out what's wrong as this isn't normal nor what is advertised, for example there is a video with a 6 channel Vitrum switch working perfectly with Fibaro.
My other single channel switches work with no issues, as expected. I hope I'm not putting HC Lite to the limit here as I have 19-20 devices, meaning over 25 entries to manage...
Many thanks!
Kostas
