blomman10 0
Could someone help me convert the following code into lua?
The code works in webbrowser but i cant get it to work with Lua and im a beginner in Lua so probably some rookie misstake im doing.
napInterval=2&sensitivity=1&triggerInterval=5&schedule0=1023&schedule1=1
023&schedule2=1023&schedule3=1023&schedule4=1023&schedule5=1023&s
chedule6=1023&area0=1023&area1=1023&area2=1023&area3=1023&area4=
1023&area5=1023&area6=1023&area7=1023&area7=1023&area8=1023&area
9=1023&usr=xxx&pwd=xxx
According to the manual below its support Get and post command.
General description
Our device can only support authentication by pass user name or password attached
at CGI request string currentlly.
For example:
We only support GET and POST method. Only importConfig and fwUpgrade can
support POST method.
The cgi request string must be encode in url format. URL encode rule:
The following chars will not be encoded:
[A~Z] [a~z] [0~9] + @ * /
The other chars will be encoded into hex format.
For example:
will be encode to:
