GreenWave node Flashing light
swapsakker
Is it just me or do i not see anywhere to enter a parameter for the Greenwave Node 6? It keeps flashing green every couple of mins now
When i go to the device and then advanced i have no parameter options, only reload parameters.
I have the parameter options by the Main_Zwave_Device, not by the separate sockets.
Strange, i dont have that option not even on the main device
Indeed strange, I checked a couple of them and all the same Can you try to reconfigure the device, to see what happens?
Reconfigured, removed, re-added, still get no parameter options. Maybe this is because of running 4.058 beta.
I simply changed polling now to 60 seconds for now, that seems to work.
You have to remove the check "Use template for parameters", then you will have the option to add parameters.
My Powernode NS310 has the parameter4: Network error: 0 LED flash on, 1 = LED flash off.
The manual seems to be wrong here. I changed the parameter 4 to 0 and the LED stopped blinking.
