FlorianH 1
I have in my home 11 danfoss thermostats and a boiler on/off switch from horstmann.
Currently I use the fibaro heating schedule to create a schedule for multiple zones at the same time and use a scene to check if I have to turn my boiler on and off. The scene I found here:
Adapted it looks like this:
I am very pleased with how it works. Turns on and off when there is some thermostat that still requires the boiler...
Now I was hoping someone could help me expand my functionality? Or point me to resources I haven't found yet.
Basically I would like to do the following, which was already asked here:
I want a scene where I constantly check if one of X thermostats has changed and propagate this change to the other X thermostats.
I think the basis of the code is this:
187 - is danfoss thermostat.
189 - another danfoss thermostat.
if(fibaro:getValue(189, 'value') != fibaro:getValue(187, 'value')){
fibaro:call(187, "setTargetLevel", fibaro:getValue(189, 'value'));
fibaro:call(187, "setTime", tonumber(os.time(t)) + 60*60);
My problem is that I don't know which one changed first, if i would add 3 or 4 in the same scene, I am completely lost. I also don't know how I would propagate the time. However I wouldn't mind if they would all change to 1 hour for example...
I could of course check all values and use the one that's unique. But that still leaves me helpless with zones that have 2 thermostats...
Thanks for any help...
Florian
