hvb83 1
I've bought a Vision ZP3102 PIR. As with their other devices my first impressions are that inclusion is flawless. About reliability I cannot say much yet, but according to others it doesn't give false triggers.
Inside is a jumper that states "Pet", so I assume this is an undocumented setting for pets, etc. Right now I haven't played with that, might try it at a later stage.
Based on reviews, I expected that the HC2 would not be able to receive the information from the sensor, but as you can see in the attachment, the temperature is shown in the web-interface. How can I access this value in order to use them in scenes?
Also, in contrast to what I know from Fibaro sensors, the sensor will only sent a new temperature once it deviates - or + 1 degree. This is not enough for controlling my in-room temperature. The manual states "the user needs to get the controller for receiving the current temperature except when the temperature +1 or -1 degree then the sensor will automatically report to the controller." I have absolutely no idea how I can do this. I've already changed the wake-up interval to 600s, but it still doesn't show decimals for the temperature. Any ideas?
4 answers to this question
