Problems with thermostat from heatit.com
Frodo
Seems like the hc2 put this thermostat in the wrong "device kind" group .
Is there any way to tell hc2 this is a thermostat or is this thermostat not supported by fibaro ?
Temperature sensor (on thermostat) works .
Adjusting temperature setting up/down do not work (should be possible from hc2 i hope)
termo1 - lets me choose between heat / energy save heat / off
termo2 -II- heat / energy save heat
Heat mode activates : comfort heat - in my case 24 degrees as i have preset in the thermostat
Energy mode activates: the temperature the thermostat have stored in eco mode. (15 degrees i my case)
Off :turns the thermostat off
Maybe it is working as it is supposed to , but i would have preferred being able to adjust temperature degree by degree..
and why is there both termo 1 and 2 .. can not see the point.
Edit: it is being registered as hvac - any way to get hc2 to see it as a thermostat?
www.heatit.com
4 answers to this question
Frodo; nice, but expensive device. I have been considering it myself. Please keep us posted about any progress
Are you running HC2? What version? I am running it with the HCL. Works good. The Icon of the thermostat is wrong but this is promised changed by Fibaro soon...
I started to use the heatit too with the following issues. (HC2 4.42)
- No template for configuration
- The temp sensor in HC2 does not match the temp on thermostat (eg. 30.2 on thermostat but only 25.3 in HC2)
- The target temp in HC2 can't be adjusted higher then 30 degrees despite a max of 35 on the thermostat
