Produno 15
Ive added this to my HC2 using V4.031 and it says theres no template available.
Has anyone had any luck using one of these with the HC2. I have it working manually, ie on/off of my combi boiler. Though i would like to be able to do this remotely using my phone/tablet.
This is the first device ive added so im not very familiar with home automation or the HC2 yet... so not a very good start
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />.Cheers.
*edit
So it seems the SSR303 is actually supported. Seing as im using only the heating for now and not the hot water control (i will be in the future hence why i bought the 2 channel device) is there a way for me to force load the SSR303 template for the SSR302 device in the HC2 so i can at least get my heating wirelessly controlled for now?
*edit 2
It seems the on off functionallity does work wirelessly after all
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />. i just need to figure out why there is 3 instances or devices instead of two..Link to comment
6 answers to this question
