HCL looses connection after power or network is temp lost
demetrio812
I've noticed this problem in the HCL: after a restart for a power lost or after the router restarts the network the HCL (connected via ethernet) is not accessible anymore.
Is anybody having the same issue? Any idea on how to fix?
Thanks,
Dem
5 answers to this question
Fibaro says Static IP.
Reported as a bug se case 0002286 Referring to case 0005023 and 0002203
Hi!
I have Fibaro HCL since may 2014 and at times my HCL loses its remote access if network gets lost for some reason.
It doesn't happen with every network issue, but if this happens, then only possible solution is to restart HCL by removing power from.
I have set static IP at first day.
Edit. My network devices and HCL behind UPS.
