Tcheri 15
Here is the answer I've got today from support for a problem logged the 21/1.
For information, Foscam cameras are not working in IE or Chrome in 4.x and it does not seems that Fibaro wants to solve something.
Do I have to make a choice between having plugins or cameras ?
"I am on my ass" as we say in french
/emoticons/default_icon_sad.gif" alt=":-(" />End by the way, we have hard time also
Dear Sir,
First off all I apologize for such late answer from our side.
We have a really hard time in this moment.
As I see in your attachment your cameras work properly only on when you use Safari browser.
On Chrome and IE the image from your cameras is not display when you use directly access. (Connection in the same network when is your HC2).
Some browser as IE causes issues with service our interface. Sometimes clean the case memory solved issue but sometimes not.
Unfortunately some cameras work properly on one browser some on different.
You also described, that all your cameras work correctly on version 3.600 HC2 software. Update to version 4.X is your own decision, it is not required from us.
If you are dissatisfied version with 4.X you can come back to version 3.600 by recovery. Of course if you want.
Best regards
5 answers to this question
