bill 0
Greetings, first post, I am a relative newcomer to all this.
I purchased a Fibaro 2x1.5kw relay switch and a couple of standalone on/off plugs.
I am using a Vera Edge and I have it setup so that when one of the lights controlled by the Fibaro relay turns on it switches on one of the standalone plugs (and relay off, wall plug off).
The issue I have is that is the relay is switched by software, e.g. the app it switches the wall plug on immediately as expected. If the wall switch connected to the relay is used then it can take upto about 30 seconds before the wall plug action occurs.
1. Presumably this setup is possible to replicate in HC2?
2. Would a similar delay occur if the physical switch operated (this isn't a delay on the connected light but rather a delay on an associated light via a Scene in Vera).
It's very early days for Vera & myself, but I'm far from blown away thus far. On the mobile app it cant take 15 seconds plus once the app has loaded before you can control anything. How does the fibaro HC2 app equate speedwise?
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />Link to comment
