Global cache serial and ip2cc commands
Guest Veil
Hi all,
Is there somewhere I can get the commands to control global cache products with hc2 virtual devices. I have the ip2ir working fine. I just need instructions for serial commands and the relay commands.
I also have some gc100 units with serial, ir and relay control, is there any special instructions to use these with hc2?
3 answers to this question
+ 1 if any body has info on this....
Thx
Edited by jabco PL
56 minutes ago, jabco PL said:
It works the same way like IR
Create VD
Put IP of IP2CC
Set Port 4998
Add 2 sets of buttons: Relay 1 On, Relay 2 On, Relay 3 On and R 1 Off, R 2 Off and R 3 Off
setstate,1:<relay number>,<0-off,1-on> ..... and 0x0D0x0A
add string for button Relay 1 On : setstate,1:1,10x0D0x0A
add string for button Relay 2 On : setstate,1:2,10x0D0x0A
add string for button Relay 3 On : setstate,1:3,10x0D0x0A
add string for button R 1 Off : setstate,1:1,00x0D0x0A
add string for button R 2  Off : setstate,1:2,00x0D0x0A
add string for button R 3  Off : setstate,1:3,00x0D0x0A
check Wait for device response
Attached VD, please change IP address of your IP2CC.
Edited by jabco PL
