norphos 0
I need some guidance on how to install my dimmer.
when I open up my switch, I can see 3 red wires, one of it connected independently to a switch socket, the other two is connected together to another socket. you can refer to the picture below. how should wire the dimmer using this 3 wires?
is there also a specific type of wire I should use? I am thinking of cutting one of my pc power connector wires for connecting the dimmer to switch . I have also taken a screenshot of the pc power connecter below.
please help! thanks
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />Please login or register to see this attachment.
