I have a Dimmer 2 with two switches. I want the S2 to control the on/off & Brightness of a Fibaro RGB Module. I've had the exact same set-up working fine with a Dimmer 1.
The problem I have is the RGB Module doesn't come on with a single click, only with a press and hold. And when it does come on its not at its last state, rather it comes on at the min level.
I don't really understand all the new associations, I currently have it set at EndPoint 0, Group 5, although I've tried Group 4 too. Whats strange is the RGB Module will switch off with a single click, it just won't switch on.
The two Modules are about 3Meters away from each other.
Any help would be greatly appreciated.
cheers
tom
    I've just tried Associating the Dimmer2 to a Dimmer1 and it works perfectly. It just struggles switching on the RGB strip. I remember I had a similar issue with a Dimmer1 Once and technical support told me the following:
    Krzysztof Gumny 10 Mar 15
    Please set for these two dimmers, parameter number 10 on value 0.
    It should solve your issue.
    Best regards
    But I can't find a Parameter 10 on the dimmer2.
