kmeta 2
Hello
I have few TKB TSM01 3in1 sensor.
I read from manulal that :
*** Temperature differential report *** This function default is disabled, to enable by setting the configuration setting NO.6 bit6 to 1. When the temperature plus or minus three degree Fahrenheit (1.67 degree Celsius), the device will report temperature information to the nodes in the group.
Do you have idea how i can set bit6 to 1, becouse HC2 do not have template for that sensor.
