properties is light not set and need a reboot
sjauquet
I just added two fgd 212 to my hc2 V3.056
First, you need to go to the settings and declare the controlled device as lightning... in my sense lightning should be the default settings.
Anyway, the main problem is that even after setting to lightning, the is light property is not set and need a reboot of the box to be correctly set.
