In the user interface the Thermostat displays the current setpoint, and it displays a time that can be set.
What is the time for? does it have any functionality?
3 answers to this question
I never used it, but I think it's for set up the temperature in your case 15°C for XX minutes. What is does when that timer ends I don't know...
In the old days (version 3.x) and you were using the heating panel, you can overrule the thermostat to a different temperature, after the time reaches 0, it will set the temperature back to the temp of the heating panel.
In version 4 I have problems with heating panel, so I don't use it anymore, so the time has no funtion for me.
Hope this clear things up for you.
If you want to make permanent change to temperature, just chose 0 minutes. Of course if you have heating panel in place, next time program will change it.
