tieske 0
I would like to have temperature settings for every room.
I have several rooms with a thermostat (kitchen, livingroom, bedrooms), and in the room settings I can pick those thermostats as the primary thermostat for that room. In rooms in which I do not locally change the setpoint (eg. hallway, bathroom) I would like to use a temperature sensor with a heating switch. I can set this up as a "linked heating device" if I'm correct.
How can I pick this linked heating device as the primary thermostat for a room? so it displays properly in the UI. Is this possible?
Or is there another way to get a primary thermostat for a room, without having an actual thermostat device in that room?
any help is appreciated.
