Guest theoverriet
I have D/W sensors with temperature sensors. In the module setting you can set an offset for the temperature measurement. It's via a slider that slides from 0,61, 1,82, to 3.03 etc. After saving however the offset is set to the nearest integer value below the value set. So 0,61 results in an offset of 0, 1,82 in an offset of 1 and 3.03 in an offset of 3. This is not what I am looking for. I want to be able to set a more accurate offset.
You can enter the offset manually (not using the slider) but this entered value isn't saved at all.
Anyone any ideas?
9 answers to this question
