nukeman 1
this is my first post in this forum. Next to the Fibaro devices i have a couple of Merten actors and switches at home and tried to integrate them in HC2. Everthing went fine except the battery powered dual wall controller (5052xx). Having a look at the the device it is discovered/configured as a Merten remote control (5052xx). Next to that the parameters and possible values are wrong . It seems to me Fibaro uses the pepper.net configuration (
). This config is faulty.The correct config looks like this:
Dual -surface push-button:
Left top button - Association Group 1 / Parameter 0
Left bottom button - Association Group 2 / Parameter 1
Right top button - Association Group 3 / Parameter 2
Right bottom button - Association Group 4 / Parameter 3
The parameter values are defined as follows:
0 - switching/dimming/shutters dual-surface
4 - switching single surface
60 - retrieve/save scene
44 - doorbell function
54 - move shutter single surface (direction changes after each switching process)
52 - lower shutter as long as button is pressed
55 - raise shutter as long as button is pressed
With this config it would be possible to define two switches on/off or 4 switches toggle (on/off)
See original Merten manual attached (config started at page 39)
It would be really great if someone at fibaro could correct the faulty device configuration
/emoticons/default_icon_biggrin.gif" alt=":-D" />I cross-checked this with the official Merten technical support
