Howto uninstall DSC, Satel and Modular security plugins
gol
In my HC2 version 4.063 I can't find any remove/delete/uninstall button to uninstall the DSC Alarm, Satel Alarm and Modular Alarm plugin.
I can't even remove a specific connect.
Have I or Fibaro missed something?
I'am evaulating if I can use the DSC plugin to a Siemens/Vanderbilt SPC alarm via my SPC Gateway.
5 answers to this question
Guest youka
I have exactly the same issue - I'm trying to remove Satel plugin from the system and I have not clue how to do that.
Are you trying to remove/delete a certain configuration? Or are you trying to remove Satel, DSC and Modular Alarms plugins from the plugin menu?
Guest youka
Well, first i tried to remove Satel device and its whole configuration - it wasn't successful, so I thought that removing whole plugin might help and I couldn't find and option for plugin deletion.
Thanks in advance for your support
Regards
Pawel
Satel plugin is preinstalled and cannot be deleted.
Whereas configurations of satel alarms can be deleted via 'X' next to the configuration on the left hand-side of the page.
Do you mean that this 'X' does not work?
