- HC2 version 4.056, from Belgium, is support z-wave US with 908.42 MHz or not???
- I can't add the Aeotec Multisensor Gen5, Model : ZW074-A with 908.42 MHz (US version) to my HC2. Nothing happen after trying so many times. How to make it work together?
Sarawut
That is not working, a Belgium HC2 is only supporting the European zwave specification. If you want to include an US version of a device, you also need an US version of the HC2.
    Thank you very much boerremk. No choice for me? i buy a wrong one?
    I agree with boerremk. I advice you to contact [email protected]. This is a user supported forum, and as far as I can tell this is a clear case: the frequency has to match, and you can't change the frequency.
