crackopl 0
i have connected fibaro switch to my heating system. It is quite simple installation. All you need to do is close circut for gas heating to start. I've set necessary temperatures, selected temperature sensor in each room and connected it to switch that is controlling heating start/stop.
What i found out strange is that system check the temperature on sensor - it is below target (target is 21.5C) so turns on switch and heating starts. After exactly 1 minute it turns of the switch...waits another (exactly) 60 seconds and starts it back again. Why ?
it's not healthy for my gas driven home heating system
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />See readout from switch starting heating - attached
