Just a question
Daneasa
Guys do you have some solutions for RAM and CPU usage in HC2?
(Decrees them)
My thanks .
Or my CPU is ok like in the pic...sometime the values are bigger
  • 1 month later...
i do not know a permanent solution but temporarily i can suggest that you power down your home center for say 20ish minutes. that will patch it up for a while.
i would allso look into your scenes and vitual devices if they do not spam network for some reason.
  • 4 weeks later...
Most likely is comes from VD or Scene's
what kind of VD and scene do you have
  • 3 weeks later...
  • Most likely is comes from VD or Scene's
    Yep , I deleted some VD's and now is better
    /emoticons/default_biggrin.png" alt=":D" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />.
    But now I have another question .
    How many cameras could Home Center 2 interface support ?
    I have a client who want 20 cameras .
    He want one HC2 and a HC Lite ( Slave ).
    I have a Synology NAS (RS411) with a Surveillance system but even that is restricted to 8 cam's.
    Your client will have to buy a very recent model NAS to manage 20 cam's..... That's quite an amount.......
    20 cameras definitely requires professional equipment (fibre optics) and even if it is possible to do it with equipment for households (gigabit switches)  you can still expect a lot of problems.
