i have a Philip PSE02 Multi-Sound Siren. This devices will show as a switch unter HC2 with Beta 4.082 firmware. If i switch it on, there is no sound but the optical alarm will flash. Now i have found a solution to switch to the different sounds with a SendData command. Here is a
where are documenting how the sounds can enabled.One example is:
How can i setup the sound in a virtual Device with fibaro and lua?
Hope you can help,
Udo
9 answers to this question
