Wemo control via ouimeaux wemo gateway
I have been fiddling with ouimeaux
here is a Virtual device that allows control of the switches if it helps anyone. it can turn a switch on and off and poll for status.
version 1, but it seems OK
Darren B.
5 answers to this question
Just what I was looking for!
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> what port do you use for the configuration?
Please, confirm that the VD works properly. Then I will move the topic to Crowd's Solutions.
Not for me, but maybe is just me. If I understand well, the Wemo switches need a port number which happens to change from time to time. I tried multiple ports but couldn't get it to work.
Again, I'm very new to Fibaro, just started this weekend with my new system
    you need "wemo server" running on a separate machine to act as a gateway.
    it runs on Linux. I have it running on a small server on an old PC running Vmware ESXi
    the default port is 5000 and when it is running, the gateway will scan and discover all the wemo devices on the network.
    you just have to make sure you have the correct device name (no spaces in name) set up in the V device.
    Ah, ok thanks.
    Probably for me to have a separate machine for them defeats the purpose of having the HC in the first instance, at least for me so I won't be able to test.
