No power, no light- what can I do?
Got a new Fibaro HC2. Plugged in ethernet, plugged into the wall, no light on the front, nothing. Tried to plug in/out several times. Using power button etc etc. Once I saw a blinking light from the ethernet port. Checked the power cable and yes, it provides power. Hard reset? Send it back?
5 answers to this question
check cables again,
try another wall outlet.
check power on the powersupply
    check cables again,
    Cables tested with some other stuff and works.
    Tried several different wall outlets.
    Same problem. Guess I have to send it back then.
    i guess, thatis the best solution then
    to be sure, did you press the on button on the backside of the hc2 unit?
    Edited by akatar
    Yes, several times, also the reset, also holding the reset etc etc, everything I was able to find on google. I'll just send it back tomorrow and we'll see what happens. Thanks for trying!
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> I'll get back to the forum when I received a working device.
