Momos 102
I know this has been discussed before but i don't recall having an answer from Fibaro yet.
So i post it again in hope that someone will look over it:
I have a lot of danfoss radiator valves LC13 and they work just fine. Heating panel is configured and does what it should.
BUT, i also have a lot of Danfoss Room Sensors, one for each heating zone. They are set as main thermostat in the room, templates are ok and all parameters are there.
What it SHOULD DO :
- heating panel should adjust the LC13 according to the ambient temperature provided by the Room Sensor - works
- when manually choosing a new temperature and interval from the Room Sensor by pressing the buttons on the device, it should update also the LC13's in the same heating zone - does NOT work. Any manual modification of the set temp and time on the Room Sensor does not get passed on to the Valves in the same heating zone.
I have a workaround using some LUA code which transmits the set temp to the valves, but the time interval is not transferred correctly. It only adjusts the set temp of the Room Sensor in the interface. The time interval is also not set - I set on the Room Sensor a time of 3 hours and it goes to the Fibaro HC2 interface as 2 hours for example. I set it to 15 mins, it goes as 2 hours again..
As both these devices are supported for sometime, i'd like to ask someone from the FIbaro team to explain what i should do to make it work correctly - any modification on the Room Sensor to be also sent to the corresponding valves in the same heating zone.
Please let me know if you need any more info.
39 answers to this question
