streilu 1
Hi to all,
maybe some of you know there is no tem
plate for mentioned device.
Including it was not a problem, the dimmer and input I1 work nearly perfect ( except status not updating in HC2 V4.100 ).
But I'd like to turn a Fibaro RGBW Module on and off by a toggle switch connected to I2.
The dimmer only shows up as one device, I2 and I3 are not showing up as individual device IDs.
Is there a way to start a scene with them alltough they not show up?
Thanks in advance!
A HC2 newcomer
