petergebruers 1,264
I was never fast enough to try 1.08 when it was released, it disappeared due to 'issues'.
It has been released again... This time with an explanation of what those issues are.
"There are a few changes that may lead to some surprise which is why the firmware was pulled down temporarily. The V1.08 firmware version should only be used if you do not plan on having the sensor reports too rapidly (<10 minutes intervals).
Battery Power
- If sensors are reporting around 4 minutes, it is possible that the sensor may send the signals 4 times in a row causing the battery to be used rapidly (users who have done this have seen battery drain within 2 weeks). (bug)
- Can be set to a minimum 240 seconds without the need to set the wakeup interval for faster reports (but is receptive to the bug above at reports <10 minute intervals)
USB Power
- Can no longer report sensors at a rate of 1 second, the minimum report is 240 seconds."
I like the way they start their post: "(...) changes that may lead to some surprise". No. Never surprised with Aeotec.
What's your experience?
12 answers to this question
