sjauquet 15
I received this message from Netatmo:
Switch to Getthermostatsdata, Gethomedata and Getstationsdata by November 30th.
Friendly reminder: Getthermstate, Getuser and Devicelist will move from deprecated to shut down. On November 30th, we are proceeding to a structural change to make our APIs faster and more powerful. Unfortunately, old and deprecated API methods won’t be supported anymore. Make sure you amend your code and start using newer methods as soon as possible for a smooth transition:
- Replace Getthermstate with Getthermostatdata
- Replace Getuser with Getthermostatdata, Gethomedata or Getstationsdata
- Replace Devicelist with Getthermostatdata or Getstationsdata
So please update your plugin if needed or there will be some problems.
Il you can add to the Fibaro Thermostat api "relay" state it would be great to know when exactly the boiler is heating.
Here is the name in the json from the netatmo API:
therm_relay_cmd: 100
And the battery status can be usefull also:
Edited by sjauquetLink to comment
20 answers to this question
