Hello Everyone,
I got a 8 channel IP relay, that i would like to control with the HC2. I grabbed the network data that's being send out when i use the buttons in the original control webpage of the relay. It looks like this:
How could i get the HC2 to trigger this via LUA? Can it be done?
I also found this.. Maybe someone can help me find out..
This triggers Relay 1 for an Pulse of 1 second, "saida1on=on" sets the relay on and "saida1off=off" sets relay 1 to off.
If i can explain anything more, please ask.. I'm struggling with this for a few days now, and can't get this to work.
Edited by robinvandienst
4 answers to this question
    No more help needed. Found it out myself.
    Great! Can you please share your solution?
    i used a virtual device,
    Internal IP adres of the device.
    TCP Port is set at 1234 by default
    Then send a string
     for channel 1 ON
    for channel 1 OFF
    for channel 1 PULSE
    For the next channel, simply change the number to the channel you want. (for example: L2\r\n )
    Very Simple, but the command list is not listed anywhere, and not included when you buy one.
    I used this relay module for a few simple devices installed 1 one place..Very cheap option (For the rest of the relays i use just normal relay modules from fibaro)
    Thank you for sharing.
