vanni177 0
Hope someone can help on it
I have the problem that some lights doesn't switch off and some randomly switch on.
In detail:
I have an ON Scene and an OFF Scene for the lights. They are triggered by Motion Sensor.
I can see after the Motion Sensor is save again, the OFF scene is running, after a while it's not running anymore and the light is still on.
The thing is it happens only sometimes, but too often.
Here is an OFF Scene:
%% properties
262 value
97 value
%% events
%% globals
CRLED
--CR_LED_OFF ID 156
local date = os.date( '*t' )
local time = tonumber( string.format( '%02d%02d', date.hour , date.min ) )
if(startSource["type"] == "other") then
fibaro:call(28, "turnOff");
else
if (( tonumber(fibaro:getValue(262, "value")) == 0 ) --Motion Dressroom
and ( tonumber(fibaro:getValue(97, "value")) == 0 )) --Motion Bedroom
then setTimeout(function()
local delayedCheck0 = false;
local tempDeviceState0, deviceLastModification0 = fibaro:get(262, "value");
and (os.time() - deviceLastModification0) >= 120) then
delayedCheck0 = true;
local delayedCheck1 = false;
local tempDeviceState1, deviceLastModification1 = fibaro:get(97, "value");
if (( tonumber(fibaro:getValue(97, "value")) == 0 )
and (os.time() - deviceLastModification1) >= 120) then
delayedCheck1 = true;
if (
( delayedCheck0 == true
and delayedCheck1 == true
and fibaro:getGlobalValue("CRLED") == "Active" )
or
then
fibaro:call(28, "turnOff"); --Light Changeroom
end, 2*60000) --delay 2min
BTW I'm sure and double confirm the variable CRLED is Active
Here is an ON Scene:
%% properties
262 value
%% events
%% globals
CRLED
Mode
--CRBF_LED_ON 150
if (
( tonumber(fibaro:getValue(262, "value")) > 0 ) --Motion Dressroom
and
( fibaro:getGlobalValue("CRLED") == "Active"
and ( fibaro:getGlobalValue("Mode") == "Day"
or fibaro:getGlobalValue("Mode") == "Evening" ))
or
then
fibaro:call(28, "turnOn"); --LED ON
0 answers to this question
