n8flight 0
Unfortunately the Northq 9021 doesn´t work as it should be. I figured out the problem with the support of the manufacturer in Denmark and thats the answer:
The firmware version on the power reader is the latest and, as you also observed, everything is reported *1000. Therefore the correct pulse factor is 1.000.000, which is the maximum value you can enter for any firmware version newer than 3.24. The problem is that Fibaro's interface doesn't allow to enter values higher than 65535 (which is the maximum value that we implemented initially until the 3.24 firmware update - when we increased it to 1.000.000).
Can you please change the implementation of NQ9021, It should be possible to change Parameter 1 pulse factor to 1.000.000. At the moement it´s limited to 65.535. The device has formware 3.30. Thank you.
9 answers to this question
