Kuba13 49
Right so for no reason other than that i was bored i played aroudn with Chinese made ripoff Popp flow Stopp,
looks same,
works same,
feels slightly better (electromotor dose not sound like its dying),
The safety pin lacks srping so you have to push it back in but that seems like only proper drawback this unit has (or do YOU have use for association from flow stopp to something? can you not just use the triggering device ... say FGFD to do that for 2 devicess?).
The actuall name of Chopp flow stopp is "GR-105N" Auto valve
contents of packadge seem eerily simillar to those of popp's own.
few tech data (from manual):
rated voltage 12V/1A
radio frequency 868,42 (using Z-Wave plus)
range 30m
valve preassure 1.6 Mpa
valve size: 1/2'' , 3/4'' , 1.5'' (no idea how much is it in CM but it loks fairly simillar to what i've seen in Popp)
Just incase somone wants to learn more of the knockoff product it has an apparent
! allright it is not Z-wave + certificate but it is recognized as befittign of Z-Wave allaince's stands (hmm that makes me think that it is infact very much like the device it is copying, it might even be made in same factory).Anny other alternatives to Popp Flow Stopp?
