I got a VD that collects lux for me and put it as global variable, yesterday i received something wrong in the readout as you could see below.
The VD collects data thru json , all code is in mainloop.
When this unexpected answer from the device shows up, the VD stop working, the only way to get it up and running again is to reboot the HC:2,
is there any other way to get the VD to start again?
[DEBUG] 18:03:49: 0.83
[DEBUG] 18:04:49: 0.83
[DEBUG] 18:05:52: 0.83
[ERROR] 18:07:56: line 7: Expected value but found T_END at character 1
Code in mainloop
10 answers to this question
" to "
Temat został przeniesiony z "
" do "
Hi @sonnyboy,
My coffee machine VD main loop stopped running recently but there was no any errors in debug window. I just open VD to edit and then pressed save button and it started running again.
    @Sankotronic
    Thanks for the suggestion, i will trie that if it happens again.
    The best would be if it restarted by it self :-)
    1 minute ago, sonnyboy said:
    @Sankotronic
    I know that for scenes it is possible to make watchdog that will monitor them and restart if they stop, but for VD main loop I have no clue at the moment how to do it.
    i use this now for my VD:S
    Code in mainloop
    Hi @sonnyboy
    Would it be possible to validate data/value before storing it in the global variable ?
    @sonnyboy,
    thanks for this link. That is what I meant and I can see there is a way to restart VD main loop using API. Nice!
    On 3/4/2017 at 10:40 AM, Sankotronic said:
    Hi @sonnyboy,
    We're 3 years down the road now, on release 4.570, and still this issue has not been fixed by Fibaro.
    I am still using Sankotronic's old tip on a regular basis when my VD derails in a runtime error for no apparent reason. I go in, edit and save. But I should not have to do it at all.
    Hi all,
    Since 4.5xx I don't have anymore problems with VD mail loops stopping. Actually to be more fair and correct, when I had some problems with my home network several VD's that make HTTP calls in main loop I found stopped and without error reported. In general when everything is OK, all my more than 70 VD's are running without any problems.
    Hi @perjar ,
    Maybe we can find the reason why you still have problems with VD main loop stop running if you can provide some more details what code is there and if there are any errors in debug windows or they just stop running?
    Tricky thing this problem.
    I still have this issue with one of my VDs. There is no error message in the debug window, it just stops executing every now and then.
    In my case, I can detect that the VD has stopped and can trigger a scene which restarts it. I am using the same prinicple as @sonnyboyuses, adding a line at the end of the LUA code.
    My code is very simple. It just adds a line with a timestamp at the end so I can trace when it happened:
