mememan 0
Hi, I'm looking to build an irrigation system and I'm curious if I could wire a moisture probe in place of a temperature probe to the inputs on either the universal sensor or possible the door contact sensor. ideally I'd like to use the former and have two temperature and two moisture probes per unit
