Hi
Would somebody be able to confirm if Send Photo to user is working for them
This was working before (I think with 4.120) and this is the syntax and doesn't appear to be working now
running 4.130...
_f
13 answers to this question
It's working with 4.120 for me.
    Thanks @szmyk
    I think it worked for me also with 4.120 but stopped with 4.130
    Hi @AutoFrank,
    I just tested with above code and it is working for me on 4.130. I get the picture on my e-mail.
    7 hours ago, Sankotronic said:
    Hi @AutoFrank,
    Thanks @Sankotronic
    Are you using a plugin or the native 'add camera ?
    On 11/06/2017 at 10:54 AM, AutoFrank said:
    Thanks @Sankotronic
    Hi @AutoFrank,
    Sorry but I don't understand the difference between plugin and native add. I first installed Foscam generic plugin and then I added my cameras with add device window. Then I selected Foscam generic plugin since my model has no dedicated one and typed in commands for my camera.
    So, I thought that there is only plugin support for cameras and can you explain to me what you meant by 'native add camera'?
    EDIT
    I have installed my cameras as devices (not plugin) and sending camera image is working fine on my HC2 with 4.130.
    I try remotely to add my camera as plugin on 4.130 but can't make it work.
    Edited by Sankotronic
    It's working for me in 4.130.
    I have to say that I'm using blockscene's for this, in combination with my doorbells
    Thanks @TRicky, I deleted my cameras (plugin based) to try and fix and can't add them back in so can't test :-) Are you running 4.13 or 4.131 ?
    @AutoFrank,
    I'm running 4.130.
    Didn't have the courage yet to upgrade :roll:
    Just now, TRicky said:
    @AutoFrank,
    I'm running 4.130.
    no worries, @TRicky Thanks
    im running 4.131 and all is well. most of my cameras are added as devices rather than with the plugin.
    sendPhotoToUser works fine
    I'm on Software Version:4.133.
    sendPhotoToUser doesn't work for me on Hikvision ds2cd2132i. I tried switching between users, changing trigger device, even manually triggering directly on device (clicking on photo button), but I don't get the email... Strange is that in past this worked flawlessly and I didn't change anything except software upgrades. Please help!
    Here is my simple scene:
    %% autostart
    %% properties
    26 value
    %% weather
    %% events
    %% globals
    if (
     ( tonumber(fibaro:getValue(26, "value")) > 0 )
    or
    then
        fibaro:call(160, "sendPhotoToUser", "303");
    %% autostart
    %% properties
    26 value
    %% weather
    %% events
    %% globals
    if (
    or
    then
    This is my experience as well
    All working okay before upgrade to 4.13
    hello all
    i have now version 4.133 beta and mine is still working fine.
    as i mentioned earlier i have set up my cameras as devices rather than using the plugin and all is well and still continues to work properly.
    i have hikvision and foscam cameras
    cheers
