alexandra_foka 0
my home center lite had a problem with recognition of the devices a couple of days before , so i recover it and tried to re add the devices. however i tried to push 3 times the button while home center was at learning mode i failed . my devices are switches 2 relays . once i push 3 times the programming button it says adding advices completed ( not finished with green color as it should be) but no device is really added ?? what am i doing wrong ? is there a problem with home center? could that happened from a thunder ??
thank you in advance
with best regards
Alexandra
10 answers to this question
