clafib 3
I have replaced the battery of a fibaro door sensor, but the battery level it was the same (low).
The soft reconfiguration do not have resolved the problem.
Then i have removed from the zwave network the sensor and re-added.
It works, with the battery level seems correct, but there is a new (strange) problem:
As a secondary id to the door sensor, is added a secondary controller that i had excluded times ago from the z-network.
Is an aeotec keyfob, excluded from the network because his pooor battery duration (3 weeks).
Now is again here, as a child of the door sensor(288.0.1).
If i put the hcl in remove mode and press "learn mode" on the aeotec keyfob, it writes something on the log but don't remove it.
If i try to "force remove" the keyfob, it will disappear from the list, but if i make a refresh of the page, also door sensor disappears.
It seems some problem with the zwave tables, or something else.
Any suggestion for removal of the keyfob and finally adding the door sensore alone ?
Edited by clafibLink to comment
