Danalock V3
Stian
Hi
I have problem adding device into a block scene I'm creating.
Timer THEN --- trying to add device but nothing happens. :/
Anyone know the problem?
here is the device
6 answers to this question
/monthly_2017_10/Lock_open.png.41618cafe304e49c9aaa1e31a5fa143c.png" alt="Lock_open.png.41618cafe304e49c9aaa1e31a5fa143c.png" data-fileid="20640" />
/monthly_2017_10/lock_locked.png.b17b0145b1467a971d634c2586e554fe.png" alt="lock_locked.png.b17b0145b1467a971d634c2586e554fe.png" data-fileid="20639" />Here you have some more correct icons.
If you use the app with BT as well, you can set it to autolock after some minutes, and auto unlock when you are coming home :-), then you don't have to use Fibaro for that.
It seems to be working here:
  • When you added the lock, did you add the lock as a device or as a lock?
    Hi
    Weird it should work, can you check if there's anything in the Triggering device?
    I have the same issue, does not work with block scenes when I choose the lock in the block nothing happens:-(
    But I can make a magic scene....
    any suggestions?
    Hi there,
    Same problem :(
    any suggestions?
