All Led on, Service Blink, How I Can Fix
HC2 was disconnected from about 5 months, I turned it on after this time, it is lighting LED  but service LED blinking, my HC2 is American Version don't have VGA conecction, I booting without the usb stick... don't work, 192.168.81.1... don't work, nothing works, any solution?
1 answer to this question
Maybe it has something to do with broken board or NAND memory.
If you unscrew screws and take aluminium plate (the one with holes for USB connectors), then you should be able to see hidden HDMI connector, that allows you connect Fibaro to a display.
Please, check that and send some photos to [email protected]. I'm sure they can help you out.
