Hello
Gabbar
Hey,
I just got my HC2 (v4.160) and 3 smoke sensors (FGSD-002). I am so excited to make it functional that I started fixes the pieces immediately.
Works:
- Got 3 lights on HC2 - power, LAN, and internet.
- Learn mode blinks when trying to add a new device via the webpage.
- The smoke sensor changes colors if I keep pressing the B-button for few secs.
No working:
Instructions are simple but somehow not able to register smoke sensors to the HC2. Quickly pressing B-button 3 times does not help.
- Tried like 10 times.
- Increased learning time to 200 secs
It can't be simple than this... am I alone with this issue? Or is there hidden trick?
Cheers,
Gabbar
@Gabbar
First, try to exclude them (choose exclude and push 3 times (quick) on the smoke sensor button
(you will see on the screen: device removed
then include device, and push the button 3 times fast (on the screen device added etc)
    Thanks, as you recommended I did and the output is:
    19:55:25] Home Center in learning mode
    [19:55:29] Device was deleted successfully
    [19:55:30] Slave Device Detected
    [19:55:30] Removing devices finished
    [19:55:50] Home Center in learning mode
    [19:56:20] Adding devices complete
    please try again to add the smoke sensor, this happens with all 3 devices?
    Hi Akatar,
    It worked like a charm on second try ... I was playing with only one sensor so far.
    Thanks a lot for your super fast help.
    PS: I will be asking many more such questions in future, as I would like to add other sub-systems also one by one and playing with HC2 :oops:
    Cheers,
    Gabbar
    @Gabbar welcome to the forum! We're glad that you joined ;)
    Check this forum
    You can ask post questions about the system and modules there. Remember to use Search tool first, it is possible that similar topic has been discussed in the past!
    And of course... Enjoy FIBARO!
