marbe 20
I have trouble with compatibility of Zipato mini keypad ver. 0.28:
- on parameter setting form Fibaro it doesn't show correct parameter 5 - Operating mode, booth options are empty.
[14:08:41] ID 269: Received parameter 5 report, value = 0
- parameter 6 - RFID circuit startup time after Home or Away is pressed - is not set, after saving I get notification and information under line is "Last set value: 50s" instead 0,50s
[14:08:46] ID 269: No report was received for parameter 6. The device might not have this parameter.
- device doesn't react to command fibaro:call(rfidZipatoID, "secure"); fibaro:call(rfidZipatoID, "unsecure");
Thank you
