Stefan87 0
I would like to control the QNAP disk storage via HC2.
QNAP I use to play movies on TV, so it does not make sense to run when no one is at home. I could turn it off with a socket, but it would not prove to be a HDD.
In a FIBARO is a module "WakeOnLan".
Did you set it up in collaboration with QNAP? Turning on after coming home and turning off after leaving?
Thanks!
3 answers to this question
