Hi!
edward.sg
Hi, bought a Fibaro Home Center Lite recently. However, encountering problems trying to upgrade the firmware to version 4.160 as well as setting up the zwave devices. Hope to get help from Fibaro forum. Thanks very much!
Hi @edward.sg Welcome to the adventure ...
I'm an HC2 user, but the update error codes are the same so maybe this helps ?
Error Code - Description
4 - Internet connection error - check the wiring and make sure that internet connection is available
5 - error while downloading info file from server - redo update
6 - error while downloading update package - redo update
7 - error while downloading update checksum - redo update
8 - checksum error - redo update
9 - error while extracting update package - redo update
10 - run.sh file is missing or is not an executable file - redo update
27 - error while copying files - redo update
30 - error while downloading a file with checksums - redo update
If an error persists, you can try rebooting the gateway, & you may try rebooting your router/modem as well.
Then try to run update again.
Any version should be OK to add devices though, so you may need to elaborate for more help on the devices :)
Cheers,
al.
Edited by alandee
