really new, from Reunion island:)
deanorth
Hello everyone
my name is Stephane, I'm 44, from Reunion island.
I want to move to this new world of connected stuff, and found this place full of informations, and Fibaro sounds like a good company so far.
I have an old Surtec alarm installed (the company that sold it to me and installed went broke so I'll have to figure out how to uninstall it).
I plan to do those things:
- manage lightning through HUE
- manage AC on/off
- manage security of my house (an alarm, a camera)
- manage fire and smoke detector
- manage external lightning
- manage netatmo weather station
and I guess there must be stuff I forgot, but well, my house is not old (7 years), but I don't want to run new wires everywhere, so wireless Z sounds good enough.
I'm still trying to understand what I really need, but I'll make a move this year for sure:)
at first you should inspect your installation: check if you have 2 wires (without N) or 3 wires (with N) in your switch boxes. It is important, as single and double switch need N wire to operate, no workaround if you want to put modules in the switch boxes. If you don't have N wire in your boxes, your only option will be Dimmer 2 which is not compatible with every type of lighting. Second thing, switch boxes themselves - check if you have enough space inside - that is the thing I am struggling a bit with - too shallow boxes. It is possible to switch them to deeper ones, but it is a "dirty work" to some extent.
You could stick to HUE, but remember that if you use traditional switch with HUE bulbs, that particular switch would need to be ALWAYS on - turning it off will cut off control of HUE bulbs through the app. I found workaround of that but it is expensive as I needed to combine HUE bulbs with Fibaro switch modules - both are bit pricey.
Best regards,
Andrzej Browarski
@deanorthOté La Réunion! Comment y lé?
You can also go to the
 (unofficial forum). The community is important. There are many very competent people who can help you and all that in French!
Edited by fredokl
Hello and welcome @deanorth ,
I'm sure you'll find answer to all of your questions on our forum!
Enjoy!
