Guest sameri
Hi guys.
Apologies if this has already been answered but was wondering if there was a way to switch the individual sprinklers between Auto/Off using a VD or similar so I can do it from the phone App?
I'd like to be able to effectively disable my sprinklers during winter and only water automatically during summer.
I know there is a good VD for the "Sprinkler Panel" (here:
but I really want access to the Auto/Off mode selection.
Thanks in advance.
Hi @sameri ,
Do you mean to tell me that you did not use the search tool ? ;)
Guest sameri
    5 minutes ago, A.Smolinski said:
    Hi @sameri ,
    Yes I did use the search tool but found nothing to help me. That doesn't mean the questions has never been answered, it just means I did not find the answer...?
    Refreshing the post.
    Is there any way to switch the sprinklers between Auto and Off mode by VD?
    Guest sameri
    I've tried my hardest today to work this out myself but am seeking some guidance.
    Using Firefox Developer I've interrogated the commands and got the following:
    The API call as far as I can tell is /api/devices/xxx/action/setDrenchingMode
    where xxx = the device ID
    Then the paramater sent is for the 2 commands I am interested in are:
    {"args":["off"]}
    {"args":["auto"]}
    Using this article:
    I have attempted to code these commands in Lua but the article does not explicitly state how to process the "arg" parameter...
    What I ended up with in my VD was (with all the General settings set the same as the example in the link above):
    POST /api/devices/xxx/action/setDrenchingMode HTTP/1.1
    Host: xxx.xxx.xxx.xxx
    Authorization: Basic Yxxxxxxxxxxxxxx=
    {"args":["off"]}
    and a few other versions of the above... Can anyone help point me in the right direction? Am I even close?
    I'm VERY new to this but trying to work through it...
    Guest sameri
    Well turns out I was VERY close... Just needed one more paragraph after the authorization.
    Very stoked. That's my first ever bit of "code" :-)
    I'll post up a finished VD later on for anyone that is interested.
    • 4 months later...
    Just adding to this thread too.. as it is more pertinent here.. this is what I have done now.
    I have a VD with an Auto and OFF buttons.. the code below is for Auto. Simply replicate it for OFF and change the mode value to off. Some reason, when I upload the code to  the  thread below, it removes the square brackets.
    Edited by rajp
    Upload edits the code.
    • 8 months later...
    With this code:
    local localhost = '127.0.0.1';
    local port = 11111;
    HC2 = Net.FHttp(localhost, port)
    response ,status, errorCode = HC2:GET("/api/panels/drenchers")
    jsonTable = json.decode(response)
    dr = jsonTable.drenchers
    for i = 1, #dr do
        fibaro:debug("Device : " .. i)
            fibaro:debug(dr.id)
        fibaro:call(dr.id, "SetDrenchingMode", "off")
    selfId = fibaro:getSelfId()
    fibaro:call(selfId, "SetProperty", "ui.lblSprinklerStatus.value", "ARRET")
    The Drenching Mode nothing changes with Firmware 4.541. What's the problem in this Code?
    Edited by speedoxx007
    • 1 month later...
    Hi @sameriI would be very interested in your finished VD.
    Do you want to share it with us?
