Hello from Utrecht
Guest Theo
Guest Theo
The block scenes did not funtions as expected so I'm starting with Lua now.
I have quite some programming experience, but it is hard to find decent documentation on the fibaro implementation of lua.
Also, analysing the code produced by blocks seems to be inefficient and hard to maintain.
I believe you can start by reading
If you have something specific on your mind please post it and entire forum will help you to learn and implement
Edited by cag014
