Hello from the Netherlands
WBA
Hi, I’m a newby on domotica /Fibaro, but hope to put together a fine working smart home. I use Homey as a controller / gateway, which suits my needs for different systems around the house (zwave, somfy, zigbee, etc.). I use fibaro products for zwave mostly, very reliable in my opinion.
Hope to learn from the community, and help others if possible. Kind regards, Wilco
Hi @WBA welcome on the community.
If you mostly use Fibaro products, why did you bought the Homey?
Doei
    Hi @Sjekke,
    I had a few systems already (Somfy, KAKU), and wanted to start from there. Initially I tried Domoticz on a Raspberry Pi, but spend most of my time learning domoticz and Raspberry Pi than on making my home smarter. Domoticz seemed a good choice because of the different systems you can combine in one controller. Expanded on domoticz with zwave dimmers, smoke detectors and plugs from Fibaro, but the hassle on domoticz and Raspberry Pi wasn't my thing. I looked at the Home Center, but i preferred the possibility to combine the different systems in one controller, so that was a deal breaker.
    Homey does the trick for me at the moment.
    Kind regards, Wilco
    7 hours ago, WBA said:
    Hi @Sjekke,
    Kind regards, Wilco
    Hi @WBA thx for the info.
    cheers
    @Sjekke
