Mosskit 4
I've been looking quite long for a device that will suite my needs:
- control of a Convector Heater in my floor with
- fancoil element support
- 3 level fan speed control
- AC 230 powered
- z-wave connected
There are several devices present on the market that provide almost that functionality like:
-MCO Home
-Heat It
-Some Honeywell Thermostats
- with a single but... they simply are too bulky to fit standard EU round 60mm electrical box and not all of them support fan control. Found that HELTUN has it all. As company is based in Armenia so I was a bit sceptical at first glance but had no choice other than try it. I connctacted they office and product was shipped to Poland in several days. It got stucked for 2 weeks on custom office however this is normal in my country nowadays especially that it was a Christmas time. Product came nicely packed see pics attached. Front panel is tempered glass covered with capcity touch buttons and controlable sensitivity level . Mounting is super easy as a whole body of thermostat you can screw to the electrical box in wall and then attach its fron panel. Whole panel seems too be not too thick (around 9mm) and nicely designed. Company offers several colours of frame and glass of front panel. All five Fan/Coil relays can be dry/wet conctact with a source of choice. They work 230AC in my scenario without an issue. Device is equipped with Light Sensor and Humidity Sensor as well. Hard to tell if humidity measurement is right as I have no other indication in the neightborhood but temp seems to be really accurate based my old devices being isntalled in same place. Screen brithenss is auto adjusted by the illumination of the ambient environment but can be also set manually if preffered. Device supports S0, S2 unauthorized and S2 authorized inclusion modes. Hardware is equipped with new z-wave plus chipset. More details you can find in a brochure and the web:
. I have also attached manual of device (2-Manual_v1.0_FanCoil_Thermostat.pdf)In terms of Fibaro HC2 interface, Heldun claims device is not z-wave certified yet but its a matter of time, thus it worked for my well with some minor bugs on iPad/iPhone apps. The COMFORT (COM) mode (called in fibaro MAX) is simply missing there. Another thing is missing dev template (already sent to @FIBARO Case Notification for #155606) See some screenshots below:
1. WEB - all ok:
/monthly_2019_01/image.png.8fda5f98697769df3b0fbaddf5b18f6e.png" alt="image.png.8fda5f98697769df3b0fbaddf5b18f6e.png" />2. ipad (MAX \COMFORT) Mode is missing
![49766489_270910186934733_3375992148905164800_n.jpg?_nc_cat=108&_nc_ht=scontent-waw1-1.xx&oh=7767079ea1f582c9762a72787765f9c0&oe=5CD1ADDA](https://scontent-waw1-1.xx.fbcdn.net/v/t1.15752-9/49766489_270910186934733_3375992148905164800_n.jpg?_nc_cat=108&_nc_ht=scontent-waw1-1.xx&oh=7767079ea1f582c9762a72787765f9c0&oe=5CD1ADDA)
![49205113_10215732422996242_3591913705496903680_n.jpg?_nc_cat=104&_nc_ht=scontent-waw1-1.xx&oh=884ef74c07b409532e2e17d852fe540a&oe=5CD365D5](https://scontent-waw1-1.xx.fbcdn.net/v/t1.6435-9/49205113_10215732422996242_3591913705496903680_n.jpg?_nc_cat=104&_nc_ht=scontent-waw1-1.xx&oh=884ef74c07b409532e2e17d852fe540a&oe=5CD365D5)
3. iphone - same here
So there is ECO, Auto and OFF mode but COMFORT (called MAX In Fibaro WEB interface).
Can someone from @FIBARO team have a look on it?
After two days of testing I found, I would call it one moderate bug of firmware with fan control. I will give you an example with standard value of histeresis of 0.5 degC (can be changed). When Deviation (SP - PV) is less than histeresis value (0.5 degC) Heater element is in Idle and FAN OFF. Once I increase SP over histeresis value (more than 0.5 degC) it starts heating element and put Low Speed FAN ON which is expected. Now, If in similiar scenario I would increase SP to value when deviation is greater than 1degC, so that SP-PV is greater than 1degC it should start heating element and put fan speed to medium but it actually does not turn fan on what is wrong. In all other scenarios (deviation value, initial state of heating element) it works properly. I have reported this to Heltun already. They were really helpfull from the begining of installation process and promissed to release new firmware January/February so keep my fingers crossed.
At the end of the day I see that product really flexible. It will suite needs of several types of HVAC installation and it suites standard electrical box. Has really catchy design with customisable panels. Retail price is 169Euro. This post is informational only and I was not sponsored by Heltun or any 3rd party company. Feel free to ask if you have questions.
Atachments:
Edited by AnonymousJohnSummary added
12 answers to this question
